miller AEAD 200LE electrical short Help
发表于 2021-10-16 15:51:19 | 显示全部楼层 |阅读模式
I recently acquired an AEAD 200LE engine driven welder and got it running descently.  The engine runs fine, and it welded great during testing.  So I cleaned it up and fixed the sheet metal on it and put it back together.  I went to weld today and I couldn't get spark.  When I glanced over at the front panel I noticed something glowing behind the louvers. So I shut down and removed the covers and found that the fine amperage control rheostat had shorted... may not have had it on 100% .  The coil melted at about the 90% range of the scale. After looking around and scanning for a reason, I noticed that the one of the 180w 12 ohm resistor  ( R4 i beleive) right under it was hot.  I did notice that the grounding wire under the resistor was stuck/melted to the bottom of the R4 resistor. Could that have been the reason it was shorted and burned the rheostat... or is it just age/corrosion getting the best of the machine?  Or is this part of a bigger problem?  Any help or process diagnosis would be helpful. I have just purchased a new rheostat, but I don't want to put it on and fire up without checking to see if there is something else wrong.  Can anyone tell me if there are any points to check before installing the rheostat to check the machine out?This machine welded really well (sadly better than my bobcat 225) in the beginning and barely made spark after cleaning it up.... So I really want to get this machine repaired and figure this out so I can leave the machine around our farm for quick repairs. Serial# HJ179340
GMT+8, 2025-12-19 13:16 , Processed in 0.129625 second(s), 18 queries .
