Connecting gas to a Miller Cricket??
发表于 2021-10-16 15:51:18 | 显示全部楼层 |阅读模式
I acquired a Miller Cricket XL and it already has the gas hardware kit installed on it.  I need a nipple fitting that goes into the solenoid valve to connect the gas supply hose.  The Miller manual describes the solenoid valve as "1/4 IPS port 1/8 orf".  Can someone here decipher that for me?  I looked up IPS and it describes it as Iron Pipe Standard.  Does the 1/8 orf mean orifice size?   Thanks for your help.
Reply:I found what I needed.  It's a 1/4" Inert Kit, Radnor part number 64003964
GMT+8, 2025-12-19 13:16 , Processed in 0.069216 second(s), 18 queries .
