Lincoln SA 200 fan belt??
发表于 2021-10-16 15:51:18 | 显示全部楼层 |阅读模式
I just got my 1946 Lincoln SA-200 short hood running, and the fan belt is in horrible shape. The number on the original is a Dayton VX-14, and the machine is a hand crank model with a F162, no alternator or tensioner. Does anyone have part numbers, cross references, correct measurements, or (most helpfully) a procedure to tighten the belt?  Thanks in advance!
GMT+8, 2025-12-19 13:15 , Processed in 0.093320 second(s), 19 queries .
