Wheel welding question
发表于 2021-10-16 15:51:17 | 显示全部楼层 |阅读模式
I would never do wheels unless the tire was off the wheel but haven't run into this before. Man working on my 2 mile long driveway broke a wheel off a Cat skid loader. Half the studs broke and half pulled through the wheel. He has a weldor/mechanic coming out that is supposed to put new studs in and is going to weld in the pulled through holes. I told him it was extremely dangerous but he said the tires are foam filled. What do you guys think? Dangerous or OK?
Reply:Just have him stand beside you and ask question.I would never weld with tire on.One mistake and you a hear loud bang if lucky and the hospital will good pain pills.Then start counting on fingers and toes see make it to 20.Dave
Reply:Welding in the center of the wheel with foam filled tires shouldn't be a problem. Still I would monitor the heat input. With the foam in there pressure build up shouldn't be an issue
Reply:This came up several years ago.  Several videos.  As I recall it was not heat build up from the source.  It was the heat causing a chemical reaction in the rubber and producing more heat and pressure.  The reaction could continue for several hours after the heat source was removed.  Thus explosion could be well delayed after repairThat's the way I remember it?
Reply:I remember that too. I agree working cautiously on the center might be ok.
Reply:That makes three of us who remember those videos....I wouldn't be standing anywhere near that operation when he welds, foam or not.
Reply:If does welding I hopping for video of the chemical reaction.  PS I hope he does try this one and he watch a video on internet . I listened to old welders and never try this one. I can still count to 20 on my hands and toes. Dave
Reply:It's a reaction that happens due to the rubber being heated.Bridgestone video about heating rims:Strongly advise against it and stand back.
Reply:Like video Dave
Originally Posted by 12V71
Yeah... But what's in that foam? and more than likely only a 16" wheel, not much room to dissipate much heat.
Reply:Very true M J D, but I have learned to always assume the worst from people.Give people a chance, they'll surprise you in miraculous and ingenious ways lol
Reply:Supposed to fix it next week, I don't plan on being close by. I'll let you know if ambulance is called.
Reply:If there are security cameras handy, can you make sure one is pointed in the right general direction for us?250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
GMT+8, 2025-12-19 13:15 , Processed in 0.070178 second(s), 18 queries .
