Welding clamps (t-slot)
发表于 2021-10-9 15:51:14 | 显示全部楼层 |阅读模式
I found these pictures a while ago.  I believe they came from this Photobucket archive (no longer accessible but you can kind of see them obscured).Are these commercial items or something he made?  The red one looks like a modified C clamp.  He's not been active on that site in years so I didn't bother joining to ask
I know Miller makes something similar but they're $$$.I cut slots in my home made table and would like an inexpensive set of clamps that mount into them.
Reply:Looks like a Jorgensen hold-down. Used to get them at Home Depot and Ace fairly cheap. I still have one. Looking for my orange version one I found this:https://www.googleadservices.com/pag...BAgBEC4&adurl=
Reply:I just use Vise-GripsSimple and fast and they just hang around when not in use.Dave
Reply:I would disregard the tee slots you cut and just drill a pattern of 5/8" holes. You can easily modify any number of clamps available to use without the hassle of using tee nuts (or ANY nuts )Sent from my iPhone using Tapatalk:
Ah yes, thank you but they lack the mounting notches.Answering my own question,  looks like this:  https://www.toolplanet.com/product/S...wn-Clamp-D4097
Reply:The Vise-Grip is more flexible for welding.I have both standard and long Vise-Grips.I can use Vise-Grip bench work, saw horse and field work. I have used this type clamp for drill press.Dave
Originally Posted by Lis2323
That's the same one El Greco posted Sent from my iPhone using Tapatalk
Reply:Looks greatDave
I chopped the threaded portion off those Visegrip DP clamps....
  and replaced it with a 5/8" stud
Reply:I got these on Amazon…similar.  Very handy.They sell the slot nuts and you can use them on any clamp if you wanted to do a bit of fab work.
GMT+8, 2025-12-19 13:16 , Processed in 0.089907 second(s), 18 queries .
