Online abrasives
发表于 2021-10-8 15:51:13 | 显示全部楼层 |阅读模式
Which online supply has the best prices on cutoff disks, grinding wheels and wire wheels? Right now I use Grainger or LWS.
"Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!
" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:Try these peeps.http://www.onlineindustrialsupply.com/09-1036.htmlwww.Markcuda.com"you didn't build that"weldor does have two "E"s
Ok,I stand corrected,there is a word "Weldor"But,in this day and age, how many frickin'times have you heard a moron use the term(spelling)?
Reply:Leighvalley abrasives. Best prices. I like their flap discs.
Reply:Ditto Lehigh Valley Abrasives. Not quite as good as 3M or other big names, but easily 1/4 the price.
Reply:Lehigh Valley does have some Sait and Metabo wheels."USMCPOP" First-born son: KIA  Iraq 1/26/05Syncrowave 250 w/ Coolmate 3Dialarc 250, Idealarc 250SP-175 +Firepower TIG 160S (gave the TA 161 STL to the son)Lincwelder AC180C (1952)Victor & Smith O/A torchesMiller spot welder
Reply:I'm a Sait guy. Love their stuff as far as wheels go. Their .045 Z-Tech wheels are the best I have used. The Pipeliner line of grinding wheels are very well priced & last quite well.
Reply:I am all over the map on this.Most of my abrasives come from EncoI have bought Klingspor for stainless work, based on a recommendation from someone who works with stainless a lot.  $50 minimum, I recall.I have just started to buy from "A cut above".  They came highly recommended, as being helpful and knowing their stuff.  Not much of a web site, just call and talk to them.RichardSculptures in copper and other metalshttp://www.fergusonsculpture.comSyncrowave 200 Millermatic 211Readywelder spoolgunHypertherm 600 plasma cutterThermal Arc GMS300 Victor OA torchHomemade Blacksmith propane forge
Reply:I go here... http://www.aaabrasives.comThey have closeouts.....From the desk of Kevin CaronTrying to be the best me I can!www.kevincaron.comAHP Alpha Tig 200x MillerMatic 251Miller Syncrowave 200
Reply:Thanks guys, Lehigh looks really good.
Reply:4-1/2 x1/8 type 27 saitech 3m cubitron pipeline cutting notching light grinding.Good luck beating my price on these discs.
Reply:I've used Roark Supply in So Cal.  Use the coupon code GRIT and get 10% off.  The no name US made flaps and cut off wheels work well. http://www.roarksupply.com/ENCO is having a Feb sale on some abrasives, Cubitron discs, CGW flaps and other import flaps, Roloc, etc.http://www.use-enco.com/CGI/INLMPA?P...2974&PMCTLG=01.Enough stuff to build and repair wrinkled up race cars or bring a classic back to life...
Originally Posted by 7A749
And pray tell, what would that be?
Reply:You called my bluff. I don't even have a grinder.
Reply:Klingspor
Reply:Red Label Abrasives has been my go-to. I originally started buying sanding belts from them, because the belts I was ordering from combat seemed to break prematurely. I've started using their flap discs too (https://www.redlabelabrasives.com/products/flap-discs) and those have been working really well. The ceramic does a good job of cleaning up welds and there isn't a ton of heat build up either. They gave me a 15% discount on the first purchase for joining the mailing list. I think they're still running that promotion. They also have quantity discounts and I'm pretty sure they run a decent sale at the end of each year. I would imagine they'll have another one this year.
GMT+8, 2025-12-19 13:16 , Processed in 0.074631 second(s), 18 queries .
