What HP is this motor?
发表于 2021-10-7 15:51:20 | 显示全部楼层 |阅读模式
I have a motor i want to use but im not sure what the horse power is. Under HP is says "Wo 466."Lincoln Pro MIG 180Chicago electric 225 ArcHarris oxy fuelEveryone who calls on the name of the Lord will be saved. Romans 10:13
Reply:If it says how many amps it pulls amps x volts = divided by 748 = HP.Ol' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
Originally Posted by scsmith42
Can you post a photo of the motor plate on the side of the motor?
Reply:Between the WO466 and speed of 3450RPM,, I would bet that is a special air compressor motor,,Typically, they are not rated for continuous duty at FLA,, instead, it is rated at continuous air compressing,, which requires less amps,,
Reply:If WO is "watts output"  then it is a bit over 1/2 HP  according to charts I have found :https://www.rapidtables.com/convert/...p-to-watt.htmlCentury buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
Reply:Looks like it was the original motor.
And the manual says it is 1/2 hp.
https://www.searspartsdirect.com/pro...-113/id-816613
GMT+8, 2025-12-19 13:18 , Processed in 0.098016 second(s), 19 queries .
