Issue with 6010 arc
发表于 2021-10-7 15:51:19 | 显示全部楼层 |阅读模式
Welding with 6010+ on either straight or reverse polarity is pretty difficult on my machine. The arc likes to extinguish frequently, and to maintain the arc as best as possible, I'm finding that I have to bury the tip of the rod in the molten flux puddle. 6011 will run completely fine at the same amperage (on AC). Is this some inherent fault of my machine, or do I need to adjust something?SRA & IWW memberCentury 250 amp AC/DCCentury 295 amp AC"The working class and the employing class have nothing in common."
GMT+8, 2025-12-19 13:16 , Processed in 0.072506 second(s), 18 queries .
