Lincoln Ranger 8 will not weld
发表于 2021-10-7 15:51:19 | 显示全部楼层 |阅读模式
Lincoln Ranger 8 run fine welded about an inch and quit. It will only spark a little on end of rod. The machine set up for about 6 months but had been used for aux power once in the 6 month period, Aux power output is fine just wont weld. The machine only has 294 hours on it. Followed troubleshooting guide including checked and cleaned brushes/rotor.
Reply:See if brushes and or commutator need cleaning. Dave
GMT+8, 2025-12-19 13:16 , Processed in 0.131869 second(s), 19 queries .
