One stage compressor issue
发表于 2021-10-6 15:51:19 | 显示全部楼层 |阅读模式
Good morning,First mods move this as needed.   I have a tool issue and thought I might get an answer at WW. I have a 20 year old craftsman one stage compressor.  It is only lightly used, nailers etc. It was beginning to bog down in the compression cycle.   I tore it down and found that the piston sleeve and rings were worn.  I purchased a replacement set. I’ll show a picture below. Anyway I put it back in service.
GMT+8, 2025-12-19 13:14 , Processed in 0.070247 second(s), 18 queries .
