Powermax 1000 air pressure
发表于 2021-10-5 15:51:29 | 显示全部楼层 |阅读模式
This morning my Pmax 1000 would not cut due to low air pressure.  If I turned my regulator down low, while the amp control was in gas test position, air would flow until I turned the regulator up to about 70 psi and then the solenoid would shut off and no air would flow.  I suspect my solenoid in the manifold had failed.  Do I need to replace the entire manifold?  It looks like the whole unit should be replaced.  Have I diagnosed this correctly?
GMT+8, 2025-12-19 13:15 , Processed in 0.066381 second(s), 18 queries .
