coffe table from square tubing.
发表于 2021-10-5 15:51:29 | 显示全部楼层 |阅读模式
Heres my last project.Wanted to make a kind of rustic looking coffe table. Since I was not  able to avoid grinding, I had to paint it, so it did not come out that rustic any more, but still.. not a bad table in my opinion.
Reply:Krikey!  Coffee table for Zeus?  Nice simple design, but don't expect the wife to lift that.
Reply:Nice looking table, really nice.  I like the distressed edges.
Reply:I like the gussets for strength!OP…nice build and I guess steel don’t cost as much where you are cause that looks expensive and that looks strong enough to work as a HD workbench as well….
Reply:Good job, nice design, and great project.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Looks great 👍Steel will last a long time Dave
Reply:Looks great... but just how big are your coffee cups??250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:You need a "sofa" to go with the coffee table, 2" x 1/4" angle, 1" solid round steel bars, steel wheels,, Composite boards, and LOTS of stainless bolts!!
Reply:Finally the right size coffee cup.Dave
Originally Posted by farmersammm
Reply:Nice work,I tend to go lighter weight and use 12x24 floor tiles for the tops and shelves
MillerMatic 252, HTP 221 w/cooler, Hypertherm PM45, Lincoln IdealArc 250 AC/DC"I'd like to believe as many true things and as few false things as possible"
Reply:Love the table. I have made a few like that. In event of tornado get under that.
Reply:I also made holes in the endplates of legs, with a M16 nut welded on the inside, so the table could be leveled(probably couple of mm adjustment is needed) with M16 bolts. But I need to find some sort of plastic caps for the bolts, so it does not scratch the floor. Something like this:
GMT+8, 2025-12-19 13:18 , Processed in 0.102815 second(s), 18 queries .
