1979 SA-200 Blackface
发表于 2021-10-3 15:51:17 | 显示全部楼层 |阅读模式
I’m selling a SA-200 welder I was planning on refinishing, but I don’t have the time and need the room in my garage. It was bought brand new in 79 by a refinery for the on-site welding. Always kept inside when not in use. Sheet metal is excellent. They stopped using it when the radiator went bad in 2012. Original brushes have little wear, and there is barely any wear on the armature. It comes with 1000$ of new BW parts including rheostat, faceplate with correct stamps, new exhaust pipe, brand new radiator, electrical switch kit, motor mounts and more. Motor turns over and compression was tested as good. I’m looking for 3200$ for everything obo. It is located in Anacortes Washington. Any questions please ask!
GMT+8, 2025-12-20 05:30 , Processed in 0.090507 second(s), 18 queries .
