Lincoln 180 dual gun issues
发表于 2021-10-1 15:51:14 | 显示全部楼层 |阅读模式
I have a lincoln 180 dual that seems to be sticking in the gun liner. I am using .35 Flux core and the wire feeds fine for a very short time then starts sticking in the liner and will not feed. It is not the tip. Do I just  get a new gun and if so, should I just go to a lincoln stock or is there aftermarket that will work with this machine. Sent from my SM-N960U using Tapatalk
Reply:is the drive roll set too tight and causing distortion of the wire?  You might be able to get a liner replacement or try blowing out the crap that is in the existing liner.
GMT+8, 2025-12-20 05:34 , Processed in 0.040551 second(s), 17 queries .
