Thermal Dynamics Pak Master 100XL NEED PARTS or SELL THIS ONE
发表于 2021-9-29 15:51:18 | 显示全部楼层 |阅读模式
I have a Thermal Dynamics Pak Master 100xl cuts 1inch3 phase or 1 phase unitit has no leads, no plug, no ground clamp, and has a bad board TD calls itFET HEATSINK (9-7015) catalog # it is $2200.00 list at TDIt appears that this has two identical boards (9-7015) in this unit so I hope that sombody out there has a Pak Master 100xl or another machine that uses this part they will sell as a parts machine or maybe you have the list of parts I need OR I will sell this one as a parts machine for $250.00 I am new to this forum and new to cutting and welding and I hope that sombody out there has some good advice for me or can help me out sorry if this is the kind if thing that is a waste of your time ;-)I like in Rogers, ARKANSAS
Reply:SOLDI noticed that almost 300 people viewed message and nobody replied?  Is there something that I am doing wrong?
Reply:This TD showed up today on CL for $100 because it has an air leak. I would get it if I didnt already have powermax 380Maybee someone here can use ithttp://reno.craigslist.org/tls/3718896591.html
Reply:You ever find  a board?
GMT+8, 2025-12-20 05:10 , Processed in 0.106495 second(s), 18 queries .
