Weldpack100 wire feed problem
发表于 2021-9-27 15:43:49 | 显示全部楼层 |阅读模式
My WP100 stopped feeding on the high voltage setting (D of A-D). All lower voltage settings feed wire and weld fine. Any ideas where to start isolating this?
Reply:i have a weldpac 125hd, about 7 years old , in good shape, mine kinda does the same thing , mine just stopped working one day when i was changing the wire, when i press the trigger i just hear the breaker clicking and no drive roller working , doesnt matter what setting i have it on , if people chime in then we'll both no the problem.
Reply:i ordered an new circuit board for my welder, after i checked the switches and everything else i could possibly check.  when i get it in i'll keep you posted on my progress,
GMT+8, 2025-12-19 13:20 , Processed in 0.111585 second(s), 19 queries .
