Plenum repair
发表于 2021-9-27 15:43:48 | 显示全部楼层 |阅读模式
Any of you guys have done a plenum repair on a car? I need to graft a donor piece into my rusted out plenum.
Reply:get your replacement part first and look at it and see which way is the easiest to fit and trim it to yours.lincoln 125spmonkey wards 250 ac/dcmiller 211 w/spool gunahp  200 sx tiglotos ltp5000dof course duramax diesel
Reply:You can't weld in a replacement unless it reaches beyond the rusted out area. I have concern you will have to attempt some portion on rusted out stuff, that won't work.An optimist is usually wrong, and when the unexpected happens is unprepared. A pessimist is usually right, when wrong, is delighted, and well prepared.
Reply:240/260z ?Lincoln, ESAB, Thermal Dynamics, Victor, Miller, Dewalt, Makita, Kalamzoo.  Hand tools, power tools, welding and cutting tools.
GMT+8, 2025-12-19 13:22 , Processed in 0.107479 second(s), 19 queries .
