Got the new Everlast SM200N aluminum spool gun to learn aluminum mig welding!
发表于 2021-9-23 23:27:05 | 显示全部楼层 |阅读模式
Just got the new SM200N Everlast spool gun, so I can start learning to do 1/8-inch thick aluminum mig welding. And I'm already REALLY liking the 20-foot cable! My machine is the reliable Power I-MIG 200, which now has another nice-quality Everlast component to work with.  The spool gun is partly plastic, but the plastic housing portion holding the wire roll seems pretty robust, sturdy for it being plastic (as opposed to thin, flimsy feeling plastic). Will be able to try it out in a couple of weeks, so pretty excited about that to share my first-use impressions.  Now ordering .030 and .035 1-lb rolls of 4043 and 5356 aluminum wire, a couple of small acetone bottles, a dedicated stainless steel brush, along with gathering scrap aluminum to practice on, just to get going. The gun did not come with a case, but a beefy Harbor Freight Apache 4800 plastic storage case works perfectly -- only $60 with a coupon.  Now I feel closer to getting back any welding mojo that I had before several years ago, when I was DIY welding mild carbon steel pretty regularly.  So hey, any tips on mig welding 1/8" aluminum with a spool gun will be grandly appreciated. (Spent most of last night looking at "Jody's" videos on weldingtipsandtricks. ��)
Last edited by Agape Guy; 18 Hours Ago at 04:28 PM.Agape GuyEverlast Power I-MIG 200 (dual voltage)Everlast SM200N Spool Gun (aluminum mig welding)Everlast PowerArc 200 stickHarbor Freight Titanium 125 Easy FluxHypertherm Powermax 30Way too many power tools
Reply:make sure the material is CLEAN, then clean it again.  100% argon and push the puddle.  All the best...report back.
GMT+8, 2025-12-20 05:08 , Processed in 0.100284 second(s), 18 queries .
