Miller 320 A/BP problem
发表于 2021-9-23 23:27:03 | 显示全部楼层 |阅读模式
Well, Thanks to 12V71, my Bobcat is running! Now I have an issue with my 320 A/BP. I'm the original owner - bought it in 1981 brand new. It's been a great machine for all these years, until now. Went to do some welding (TIG), and the arc was pretty weak. Now, I only have a very weak spark when the Hi Freq is on. It will stick weld fine. The foot pedal is fine because I have the same issue in standard or remote contactor. The only "weird" thing that's happening is that the soft start rheostat is warm - I don't use it and it's switched off. I did blow it out, and clean all of the contactors, no broken/bare wires, fuses all good. Any help will be appreciated! Thanks! ----------------- John
John
Miller 320 A/BPMiller Auto Arc 50Miller 150 STHMiller 225NT Generator Lincoln SP-200PlasmaFix 50S Plasma Welder"Cheap ***" Plasma CutterMachine Shop
Reply:water cooled torch? open weld conductor inside the red hose.Replace or rebuild torch.
GMT+8, 2025-12-19 13:21 , Processed in 0.065283 second(s), 18 queries .
