Lincoln powermig 255 problems
发表于 2021-9-23 23:27:03 | 显示全部楼层 |阅读模式
Have a powermig 255 that the volts won’t go down. You can turn the knob and the digital display shows the volts going up or down but when you weld it is like they are all the way up. Sometimes it will weld normal or like they are all the way down but most of the time it is hot.  Have put a new pot on it just because it was cheap to try but didn’t change anything.Equipment:Lincoln Ranger 8Lincoln Power Mig 255Miller Diversion 165Hypertherm Powermax 45Victor Pro Series Torch setTons of other shop supplies
Reply:Since is does work once and a while. You might just have a loose connection in the feed back circuits. either the wires from the shunt or the voltage wires from the output studs. Get the diagram from the owner's manual or the one pasted on the side panel. find wires 205 and 206S they come from the current shunt. diagram shows it as a box just above the output choke. wires 206 and 207 are your voltage feed back to the control pcb. Check wires for cuts and damaged insulation. then check connections to shunt and weld terminal. Then look at plug to control pcb.Look into the plug connections and make sure the hole is not larger then the other ones. If all connections to the pcb check out OK. then pcb may be bad.
GMT+8, 2025-12-20 05:10 , Processed in 0.100074 second(s), 18 queries .
