My friend and customer Chuck wanted a sturdy pole to hold a bird feeder bracket. The problem is that for some reason the arm of the bracket was three feet long, so it would apply a moment load to the pole. The other problem is that he wanted to mount the bracket 6-1/2 feet high so that people could walk under the bracket without hitting it. The first step was to make a SolidWorks model of the pole.1. Concept Model
I find that my mister is great for keeping the part cool while taking heavy cuts.2. Mister to keep part cool
I needed to cut a slot in the pole. To fit the pole in the room where my milling machine is located I had to rotate the waist of the Bridgeport and extend the ram as shown below.3. Offset waist of Bridgeport
4. Slot milled
I used my lathe to chamfer the end of the pipe. I know that the chamfer doesnt require the accuracy provided by the lathe, but I have a lathe and this is a very fast operation.5. End chamfered Smith Oxyacetylene TorchMiller Dynasty 200DXLincoln SP-250 MIG WelderClausing/Coldchester 15" Lathe16" DuAll Saw15" Drill Press7" x 9" Swivel Head Horizontal Band Saw20 Ton Arbor Press BridgeportLincoln LE 31 MP & Lincoln 210 MP
Reply:6. Loose parts are made
7. Tack welded the tap plate
8. Tap plate welded out
9. Tip welded to tube
10. Cross plate welded Smith Oxyacetylene TorchMiller Dynasty 200DXLincoln SP-250 MIG WelderClausing/Coldchester 15" Lathe16" DuAll Saw15" Drill Press7" x 9" Swivel Head Horizontal Band Saw20 Ton Arbor Press BridgeportLincoln LE 31 MP & Lincoln 210 MP
Reply:11. Tip painted
12. Cross plate painted
13. Cap installed on end
14. All done Smith Oxyacetylene TorchMiller Dynasty 200DXLincoln SP-250 MIG WelderClausing/Coldchester 15" Lathe16" DuAll Saw15" Drill Press7" x 9" Swivel Head Horizontal Band Saw20 Ton Arbor Press BridgeportLincoln LE 31 MP & Lincoln 210 MP
Reply:That's just beautiful. I really enjoy posts like this. As a fledgling wannabe weekend warrior, these give me goals to shoot for. Also reminders that just because something seems simple it doesn't mean I should take any shortcuts or not go 100% to make it well.Yeswelder MIG-205DS(3) Angle Grinders at the ReadyJust a hobbyist trying to improve
Reply:Awesome.I would have had to try it out as a javelin before painting...
Reply:Watch out for the squirrels, little buggers are always swinging off my wife's feeder trying to ge in. DIY CNC Plasma table USB BOB Price THCHypertherm 65Everlast PowerTig 255 EXTMiler 180 Mig13" metal latheMill/ DrillECT, ECT,
