Receiver for Rear of Trailer
发表于 2021-9-23 23:26:59 | 显示全部楼层 |阅读模式
My friend Rick wanted me to fabricate a receiver that would mount to the cargo carrier on the rear of the trailer that would allow him to install a bicycle rack to the receiver, when desired. With this design the bicycle rack would be easy to remove from the cargo carrier when it wasn’t required. Rick originally wanted to use a piece of angle iron that he had for the cross brace, but I talked him into using a piece of square tubing, for improved torsional rigidity.  I didn’t want the bicycles to bounce around too much -- particularly the heavier electric bicycle.1. Original Plan
Rick wanted the bottom of of the receiver to be flush with the deck to we installed the receiver tube offset on the top as shown below.2. Offset receiver
I welded a tab to the top of the cross tube to close off the hole caused by the offset receiver tube.3. Offset tab
Notice the Fireball square that I  used to square up the receiver to the cross tube.4. Tack welding
5. Welding it out
Smith Oxyacetylene TorchMiller Dynasty 200DXLincoln SP-250 MIG WelderClausing/Coldchester 15" Lathe16" DuAll Saw15" Drill Press7" x 9" Swivel Head Horizontal Band Saw20 Ton Arbor Press BridgeportLincoln LE  31 MP & Lincoln 210 MP
Reply:6. Me welding the end cap
7. End cap welded
8. Bottom of receiver welded
9.All welded top view
10. Welded bottom view
Reply:11. Painted
12. Mounted on cargo carrier
-Don
Reply:I would replace the pin in the receiver with a 5/8" fine thread bolt lock nut to take the slop out.
Reply:How are you liking that Minion square?  I've been thinking about getting a set since they're smaller than their brothers, but....
Reply:That will work. When through bolting wood, using 1/4" plate and drilling a hole excedes a basic flat washer. Sent from my iPhone using Tapatalk
Originally Posted by Don52
I It also has knurled screws so that you don’t need any tools.
-Don
Originally Posted by Lis2323
Hey!  I also use knurled screws on my homemade squares. LOL
Reply:Here is a picture that Rick just sent to me showing the bicycles mounted to the rack.
Reply:with the bolt idea, how about making bolt over length then drilling a cross hole so a padlock can be put through. then not only will it stop a thief just unbolting it and walking off with everything, it also means that if bolt starts to back out it can't go very far.
Reply:if it makes it more awkward to steal, only those who really really want it will have a go at it.
GMT+8, 2025-12-20 05:32 , Processed in 0.096064 second(s), 18 queries .
