Lincoln Pro Mig 180
发表于 2021-9-23 23:26:51 | 显示全部楼层 |阅读模式
New to welding.  Purchased a 140 but I will probably need to weld at least 1/4 inch steel sometime soon. I'm not seeing much here on the 180. Is it worth the Upgrade? Thanks.
Reply:Never mind.  Just read a good post on it.
Reply:Which good post?   Did it say the 180 was 2x as good as the 140?www.urkafarms.com
GMT+8, 2025-12-19 14:30 , Processed in 0.095118 second(s), 18 queries .
