Hobart ma5040d
发表于 2021-9-23 23:26:49 | 显示全部楼层 |阅读模式
New to this forum so if this is posted in the wrong area sorry. I have a hobart mega arc 400 amp arc welder/generator with perkins diesel engine and it has stoped building up voltage at the receptacles and at the leads. No voltage at all. Any suggestions. It sat for probably a year with out striking an arc or using the receptacles but was started several times. Do i need to polarize the generator? I’m lost. It does not have a automatic high low it’s just one RPM when running.
GMT+8, 2025-12-19 14:29 , Processed in 0.095893 second(s), 18 queries .
