Powcon 550 to single phase
发表于 2021-9-15 11:17:17 | 显示全部楼层 |阅读模式
Hi, I am trying to convert the 550 Powcon to single phase.  I changed the tabs from 460 to 230. The plug is where I'm confused.  I hooked it up without the red wire  Turns on, fan turns on but not sure of it's correct.  Anyone have any suggestions.  Thank you,Ruben
Reply:Hi Ruben,If it turns on and fan is running, then it sounds like you've got it right.  Are you having other issues with it?Best regards,Mike
Reply:By Yes, it runs.  I got the 550 manual and it gave single-phase instructions.  I used 3 wires green white and black.  Then isolated the red per the manual.  Now just trying to hook up the power drive 1 to it.  The point doesn't match up.  I need to get a diagram for the power drive.  Any suggestions.  Thank youRuben
GMT+8, 2025-12-19 14:27 , Processed in 0.195182 second(s), 18 queries .
