Lincoln Weld -Pak 180HD with Dual Sheild
发表于 2021-9-13 10:34:10 | 显示全部楼层 |阅读模式
Hey Guys I want to know if its poossible to run dual shield with this unit. This machine has the gas and valve setup included. Im going to be working on 14 gauge steel but also some 1/4" steel  that will probably require multiple passes with flux core.
GMT+8, 2025-12-19 08:00 , Processed in 0.115576 second(s), 18 queries .
