I Gots Big Nutz
发表于 2021-9-13 10:34:09 | 显示全部楼层 |阅读模式
Some of the partz for the pipe stands arrived on Friday.............................
  1" Acme threaded nutzzzzzz.  It's all coming together I guess.  Everything's goin' down the crapper, but still paddling
Reply:Whenever I order stuff from Mcmaster-Carr like that, I think of Wiley coyote ordering stuff from Acme Supply Co.
Airco 250 ac/dc Heliwelder Square waveMiller Synchrowave 180 sdMiller Econo Twin HFLincoln 210 MPDayton 225 ac/dcVictor torchesSnap-On YA-212Lotos Cut60D
Reply:I've got some acme rod here that I keep meaning to get some nuts for.  I just keep forgetting to measure the stuff to see what size it is.  I'll look forward to seeing the stands you build.
Reply:Years ago I made some support rods ( I think they were about 1") to pull a building back together that was starting to spread. On the joints between the threaded rod and the plain rod I welded them together and slid a pipe over the joint and welded both ends of the pipe. Anywhere I was joining 2 threaded rods I used extended nuts.... similar to what you have but they are about 3" through. Everything was holding fine when we finally demolished the building.250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:some of the nuts on the draglines we work on you got to make a wrench or socket for unless you feel like payin 300 bucks for a tool you might use once evry 30 years or so and they are big like maybe 6  inches across the flats or more. Then weld eyes on em and pull em with a comalong....makes for a long day for about 6 of em
Reply:I hate to say it out loud, but my nuts aren't that big.... the wrench I needed was around 2 3/16 for the gang bolts of the tandem disc. I made one for the fixed square end, and was in the process of making one for the hex end when I found the cylinder bar wrench from an old combine was close enough to jump on.
GMT+8, 2025-12-19 14:30 , Processed in 0.094491 second(s), 18 queries .
