Still loving the multimatic 235
发表于 2021-9-10 14:18:43 | 显示全部楼层 |阅读模式
This is with 030 lincoln wire. Im making an attempt to start making my stuff look good.Outside corners are at 19.5v 385 imp1/4" material Inside is 20.9/440She's burned a 44lb 035 spool now. Im testing a 12lb spool of superarc 030. So far i like it.Last pic left weld is 035 right weld 030 both at 21vThere still seems to be a lack of internet exposure on this machine so far i like everything about it. You can spin the ipm dial and itl burn itIve played with it to 25v and 500 ish ipm still lays it down though i had to stop to darken my hood.Its definitely helping me get better
Sent from my SM-G781U using Tapatalk
GMT+8, 2025-12-19 14:29 , Processed in 0.069145 second(s), 18 queries .
