Powcon 300SM
发表于 2021-9-9 17:18:43 | 显示全部楼层 |阅读模式
Since they dont make Powcons anymore I thought I'd ask do you all think $325 is a decent deal for a working Powcon 300SM without the feeder?
Reply:Yes.  You can download the manuals from Arcon welding.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I have owned a couple, even had I one of the rare ones with a 6010 port.  They make a bunch of squealing noise when welding,  That's normalTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I think that is a good price and would not hesitate to drop $325 on a working 300SM.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:Yep! it is.Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal Mill
Bryan
Reply:Thanks guys. One more question on the Powcon 300SM. What type of wire feeder can be run on one of these? Can you run a Miller 12vs or a Lincoln LN 25 off this thing?
Originally Posted by soutthpaw
Yep, as suitcases get their power from the work clamp and weld cable to the suitcase, you just set it to CV mode and go. You don't need a voltage sensing feeder either.  just about any 115 vac stationary wire feeder can be wired up to this machine.  Check with Steve (7a749) if you are looking for a feeder, I think he had a few available
Reply:Put it on GMAW (short circuit) to start.  You will be setting the volts.   For flux core, the work clamp needs to go in  the + terminal. - goes to feeder.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:THX, Southpaw, I got it going right. This thing is the dream machine. Now I'm wondering what I even need a CST 280 for?
Reply:GMAW = Gas metal arc welding =MIG Metal inert gas SMAW = shielded metal arc welding = stick.Takes a while to learn all the short hand and there is quite a few.
Reply:Hey Southpaw or anyone else with the answer. I'm now fiddling with my 300ST (tig unit). I've just discovered when the arc start/gas control switch is placed in the GTAW position I get nothing. No arc, no gas solenoid functioning, nothing. If I leave it in the SMAW position (with leads swapped to DCEN just the same of course) and not route the gas line through the unit just straight to the rig It tigs all day long great. It's just the internals of the GTAW are not working when switched. Not a necessity to tig but if I can fix it on the cheap I am. Bad switch maybe?
Reply:@SouthpawThanks dude.
GMT+8, 2025-12-19 14:30 , Processed in 0.089603 second(s), 18 queries .
