3M Half Face Respirator Replacement Filters
发表于 2021-9-9 17:16:14 | 显示全部楼层 |阅读模式
I have the above half face respirator. Brand new, never been used before.  Used it for about 2-1/2 hours manually plasma cutting 16 gauge cold roll sheet metal.  At the end of 2-1/2 hours could barely get air through the filter cartridges.  Not getting enough air/oxygen.  Took it apart and cleaned it thoroughly with mild soap and water.  Took the 2 flapper valves off and cleaned them as well.  I think that the dust from cutting clogged the large filters.  Is there a way to clean these?  Air gun?  Water?  These are pretty expensive for 2-1/2 hours use, and yes I know it is for protection of my lungs.Thanks for any advice on how to extend the life of the filter cartridges.
Reply:No way that I know of.   I hope you have extras.  They're pretty expensive right now.  I was barely able to get some on Ebay NOS for $15 a pair.  Better NOS than nothing.
HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Weird. I use that and switch them out every  2 weeks or so just for piece of mind. Never had them actually clog up Sent from my SM-G930W8 using Tapatalk
Reply:I've never had one clog up like that either.Maybe it got wet?  Perhaps the exhaust valve was stuck and you were breathing humid air into the filter/particulates.A few layers of cotton fabric (depending on thickness) enveloping your filter helps pre-filtration of the bigger stuff.If i can't find filters soon i'm going to look into buying HVAC filters (or comparable media) and cut them up/hot glue to fit.  Drastic times my friends.
GMT+8, 2025-12-19 08:02 , Processed in 0.100845 second(s), 18 queries .
