2022 F350 headache rack (measurements needed)
发表于 2021-9-7 08:23:52 | 显示全部楼层 |阅读模式
The new truck I ordered came in, I need to build a headache rack for it. Can someone give me the measurements for the the plastic bed cap clips. I can't get an accurate measurement of the clips and Im afraid to remove the plastic caps with out breaking them. I need these measurements so I can bolt it to the bed.
Reply:How long did it take to get it?  Heard some people were told 10 months or more on new orders.Century buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
Reply:Ordered in May 26th, was delivered August 9th
Reply:You need to remove that plastic cover anyway so dont matter if u break it. It will be covered by the rack anyway. Take it out and measure inside on one and outside on the other. That will give u center
Reply:I don’t know if my F-150 (‘16) is the same, but I used a screwdriver to pry caps out and caps were only very slightly marred by removal. Area around hole wasn’t marred. Capswill likely never be reused as Backrack will stay on truck.On a side note: Is there a better way of attaching a rack(without drilling holes)than the  J-bolt ?Miller a/c-d/c Thunderbolt XLMillermatic 180 Purox O/ASmith Littletorch O/AHobart Champion Elite
Reply:Im going to set the headache rack on top of the caps
GMT+8, 2025-12-19 14:27 , Processed in 0.100920 second(s), 18 queries .
