Brake line bracket
发表于 2021-9-7 08:23:52 | 显示全部楼层 |阅读模式
Working on my 1975 Toyota FJ40 brakes Have to make a bracket to hold one of the brake flex lines in place It`s L shaped w 9/16 hole drilled and WELDED in place to the rear axle thx Buz K
Reply:And Sooooooo......www.tjsperformance.comDynasty 300 DXHTP 240HTP Microcut 380Hyperthem 85JD2 Hyd Bender and HF Hyd Ring Roller all in one =(Frankenbender)Bpt. Mill/DRO4' x 8' CNC Plasma TableInstagram: tjsperformanceYT: TJS Welding and Fabrication
GMT+8, 2025-12-19 14:27 , Processed in 0.093721 second(s), 18 queries .
