victor flowmeter hrf 2325 leaking at top of glass
发表于 2021-9-7 08:23:41 | 显示全部楼层 |阅读模式
i unscrewed this and the orings look fine,, i think what is leaking is the "burst capsule"?     it seems rather ridiculous to pay 50 bucks for a rebuild kit just for one little part.  also, the rebuild kits i have found are for a hrf 2425,  vs my 2325,   i sorta assume the kit is interchangeable with my older regulator.   can anyone confirm? does anyone know where to just buy that part?  (at least i think that is what the problem is)i had recently turned the regulator up as high as it would go as i was trying to gas out some voles in my lawn.  (this did not work, btw)    fast forward a few months i go to do a little welding and it's leaking at the top,, i suspect the ball flew up and did something to the top of the inner tube.another question,, i see regulators on ebay for dirt cheap, the whole regulator, for like 29$.    i really don't weld much any more.    are these regulators trustworthy,,, obviously cheaply made in china i have no doubt.  thanks for any input
Reply:The repair kit for the 2325 is not the same as the 2425.https://regulatortorchrepair.com/pro...kit-0790-0120/
GMT+8, 2025-12-19 14:30 , Processed in 0.090695 second(s), 18 queries .
