Power Cool W400?
发表于 2021-9-1 23:19:41 | 显示全部楼层 |阅读模式
Anyone know the dimensions of this unit?  Looks like it might be intended to mount under a welder.  I've got a 255EXT and am going to buy a water cooler; be nice if the W400 would fit under it.
Reply:It will, but you will find that the cooler is a bit oversized for the unit.  It is designed to nest under the larger units, such as the 350EXT.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I have the 350 EXT and use the smaller W300, it has been fine.  The W400 wasn't available at the time.  I've run my 20 water cooled torch at 260 amps and the torch never gets hot.  The W300 is plenty of cooler for the job, though I'm happy so see they offer a bigger unit now, which I would have gotten if it were available last year.Everlast 350 EXT       -        Thermal Dynamics Cutmaster 52         -         Rogue Fabrication M600 xHD tube benderMilwaukee 4208 Mag Drill          -         Shopmaster Eldorado Combo mill/lathe machine with DRO.
Reply:Dimensions are roughly 30"L x 11"W x 10.5"H.  The height is taking into account the feet and top stacking rails.
Reply:Seems to stack up just fine.  (Had to move around the top and bottom standoffs though.)
GMT+8, 2025-12-20 12:43 , Processed in 0.069093 second(s), 18 queries .
