255EXT post flow running on
发表于 2021-9-1 23:19:40 | 显示全部楼层 |阅读模式
Anyone know why the post flow would continue to run on with my 255EXT? the post flow is set at 0.01963 SA 200 Redface, rebuilt by me, bodywork by CEP
Everlast 255EXT w/W300 coolerMiller 212 AutosetMiller Xtreme 375Bridgeport MillSouth Bend 9" Lathe
Reply:Call tech support at 877 755 9353 ext 207www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:What does it do with it set at a "normal" time of like 5.0 or 10.0?Some systems I work with 0.0 means always on, not alway off.  Logical being that no "time limit" means "always".Everlast 350 EXT       -        Thermal Dynamics Cutmaster 52         -         Rogue Fabrication M600 xHD tube benderMilwaukee 4208 Mag Drill          -         Shopmaster Eldorado Combo mill/lathe machine with DRO.
Reply:I am not sure why you would have a post flow set to 0.0? Maybe this can be explained, defiantly a new one to me. I think Chad86tsi is correct in his reply. I might go check mine.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:It wouldn't be that.  Post flow set to zero on this unit is zero.  Likely trash or a connector that needs to be reseated.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-19 14:54 , Processed in 0.176985 second(s), 18 queries .
