new Everlast 210EXT won't start arc (AC TIG)
发表于 2021-9-1 23:19:40 | 显示全部楼层 |阅读模式
I'm puzzled.  Last time it worked fine.  Today on the same programmed settings it won't start an arc.Its intermittent too.I'll try starting an arc right on the groundclamp, and sometimes only HF and other times a full arc, but about 8 times of 10 nothing happens.Sometimes the relay clicks, sometimes no click, no gas.And the relay clicking .... doesn't start HF or the arc.It's only 3 months old, and came with the 'new' NOVA pedal.Here's a pic of the settings.  I don't know why it's sideways, it's correct on my computer.
It's on "saved setting #2" that welded that aluminum in the pic (last time I used it).
Any ideas what to look for?  I have a project and I need it to work.
Reply:As other already suggested (in the other post in General) I would contact me manufacturer (or dealer) right away and see if they can guide you through checking the machine to troubleshoot it.But keep in mind that inverters are just like that. One day they work just fine, next day they don't spark at all. If something goes bad and you have to replace a board, it can get expensive. Let's hope it is something minor!
Reply:Not probably a big issue.  You should call us though at 877 755 9353 ext 207 for best support. Check your ac balance setting and tungsten type.  Are you using helium? If so how much? Make sur it isnt contaminated.  As far as price, if it is in warranty and a failed item it is covered.Also, it may be helpful to remove the resr cover and make sure all main board plugs are plugged in.  Cueck point gap for .030 to .045 gap.  Trend it on the smaller side.  Make sure every thing has been unplugged first before attempting a case removal for at.leat 10 minutes.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I called. They said it could be reversed polarity which it was. Somewhere I’d heard to have the torch on on pos for Aluminum but Everlast said torch is negative always for inverter TIG.  Did a quick weld on 1/4” Alu (@200A) and all seems well (I think .... )
Reply:Always check the manual. It has pictures to follow even regarding polarity on TIG.  I don't know of any TIG welder where you change polarity from DC- to weld AC.  Even with welders that have a polarity switch, it isn't usually changed, or the default is negative polarity.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-19 14:52 , Processed in 0.069308 second(s), 18 queries .
