"Newish" Power i-MIG 200E
发表于 2021-9-1 23:19:39 | 显示全部楼层 |阅读模式
This unit has been on silent release for 6 or 8 months now.  We haven't said much about it.  It sort of has been selling itself and sales have really tripled and then quadrupled recently on it.  It's the "big" brother to the Power i-MIG 140E.  This unit he is testing is a production run.  Not a pre production or anything like that.  Originally we brought this welder out about 3 years ago, but it was only 240V then.  But we pulled it and reworked it in the meantime for dual voltage release. Apparently that was the trick and the timing was right.  It is a bit lighter on duty cycle than the standard, heavier duty Power i-MIG 200 (180A @ 25% vs. 200A @ 35%), but if you want a 200A MIG welder well under 600.00, this is what you have been waiting for! The unit is capable of welding up to 200 amps.  No digital display, but as you can see, none needed here. Dual Voltage.  8" roll capacity.  Spool Gun ready. No stick mode.  No arc force, just pure MIG.  If you compare to the transformer and even new "inverter" models out there in this range they don't feature anything more.  For what it does and how it performs, it is an excellent choice.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
GMT+8, 2025-12-19 14:52 , Processed in 0.070721 second(s), 18 queries .
