256SI Plasma function Inop
发表于 2021-9-1 23:19:39 | 显示全部楼层 |阅读模式
So i was cutting 1/2 plate and burned through the insulating cup and the other small consumables a few weeks ago; ordered parts from Everlast and tried the unit after replacing said parts. Pilot arc is not working; air flow is fine. Calling Everlast tomorrow...just wondering if anyone has some quick info. Troubleshooting guide mentions a fuse; is this located inside the case?
Reply:No fuse on the updated model. But the most common cause ( I have dealt with this 4 or 5 times this week alone) is that the customer has dropped, lost or ignored the swirl ring.  Sounds like this is likely one of those cases.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Is that the brown thing, illustration not so good in manual and i think everything is there....
Reply:I just watched Kevin Caron's vid on repairing the plasma torch; i think my swirl ring is MIA...now to see if it is still around or if i have to order.....
Reply:The first picture is not your torch but shows what the part are and the second picture show all the consumables for your torch.
www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:My previous post disappeared...weird. Anyway, i found my swirl ring, so i think my "problem" is solved. George, I would like to order from you but somehow we had difficulty connecting before....i would like to get some drag tips like item 14 and 15 for my torch.
Reply:Drag TIPS are item #6 and 10 and only rated at 40 amps. Standard shielded consumables for drag cutting are item #3, 13, 14 and 15 and come in 40, 50 and 60 amps. Extended shielded consumables for drag cutting are item # 8, 16, 17 and 18 and comes is 40, 50 and 60 amps, all these are listed on my ebay store.Last edited by mechanic416; 09-10-2018 at 01:08 PM.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Checked your page, link seems inop. Think we went through this before. Can you sell by phone?
Reply:If you have a paypal account and a US addresswww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:if you mean CONUS I am out of luck; US territory with USPS box, then yes.
GMT+8, 2025-12-19 14:52 , Processed in 0.072042 second(s), 18 queries .
