Problems with Everlastgenerator forum?
发表于 2021-9-1 23:19:37 | 显示全部楼层 |阅读模式
Tried to register there as Metalman21, took a few days got an activation email. That didn't work and now it's responding incorrect user name or password. They are correct.  Never recall having this much trouble registering to a forum so I think something is wrong there. I forgot what questions I wanted to post and kind of lost interest in the wait.Ernie F.
Reply:No, it just has to be manually approved.  We had a really bad issue with thousands of bogus subscribers that posted several thousand bogus posts in a few days. I'll check and see if I can do anything.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Just checked and don't see you listed.  Could something have gotten accidentally spelled wrong?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Something isn't right.  Just looked up "Metal" to find anything close.
Reply:That isn't the user name. I tried it with Metalman21 and metalman21 and I re-typed the pass word with no results. Why did I get the activation email?Ernie F.
Reply:Did you respond to it?  It's sent out to verify you aren't a spam bot.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I did respond. Thought I had to use it to complete registration. So is the software considering my user name as spam?Ernie F.
Reply:Did you sign up on the site or on the forum? The two are separate and different process.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I registered on the forum. What is signing up at the site for? I appreciate your looking into this.Ernie F.
Reply:I had the same issue as you did, and like you lost interest. Recieved the Email and everything, but could never log on. Lugweld if you can check my user name is either Boostr or boostr I forget because it was a while back.THAT'S HOT!
EVERLAST POWER i MIG 140E*SOLD - Forney Easy Weld 299 125FC
GMT+8, 2025-12-19 16:17 , Processed in 0.108493 second(s), 18 queries .
