Can't find the serial number on my victor regulators
发表于 2021-9-1 23:19:37 | 显示全部楼层 |阅读模式
At the beginning of May, I bought a set of Victor Edge 2.0 regulators from 2 different vendors.   there is a $50 rebate on each, but the rebate form on the ESAB site requires a serial number to be able to submit the form.  Problem is I cannot for the life of me, find a serial number on these regulators.  Any body know where it could be or if they even have one?  They are a 0781-3603 acetylene, and a 0781-3600 oxygen 0-60.Victor Oxy weld/cut Setup Meco Midget Torch outfitEverlast 2016 250EX & Power Cool W300Lincoln Power mig 210MP  w/amptrol and Spool GunEverlast Powerarc 200 Hypertherm Powermax 45Bandsaw, Lathe, grinders, press, Bridgeport, etc.
Reply:Not sure on the edge2 regs but the others had a foil decal with the specs and s/n. If there is no s/n you can get with your local ESAB rep and he or she should be able to push it through. If there is a local rep. Most have vacated the company or won't even know what an edge regulator is. Or you can prove it's an Edge 2 simply by showing the newer style gauges. Customer service may help you too. good luck.
Reply:Sux to cut coupons.If you had bought it from_____ at the LWS the problem would be a non-problem.$50 is $50......about an hour+1/2 in my world.If my gauge /reg craps they'll hand me a loaner until the other show is resolved.Same with my freezer, fridge, dryer. They'll stuff a floor model in until____whatever___is resolved.NOOP. I didn't get a bargain.Neither did you.
Originally Posted by Housedad
Considering that the LWS wants over $250 each for the regs, I got a 'bargain' online even without the rebate.  On top of that, considering that the LWS is Mathesson and they treat me like crap because I'm not a major user,  the only thing they get out of me is for the bottles and only due to nobody else around.  I don't throw my money at folks that treat me like they do.
GMT+8, 2025-12-19 14:52 , Processed in 0.121279 second(s), 18 queries .
