Primeweld TIG225X Hand Control?
发表于 2021-9-1 23:19:31 | 显示全部楼层 |阅读模式
Hi y'all,I picked up a used Primeweld TIG 225x and finally got around to trying the hand control, which doesn't seem to work right. When plugged in, the amperage is no longer adjustable, and the number goes down to something around 15-20 and acts funny (like somewhat adjustable with the AC balance or frequency knobs). Arc lights, but is weak and sputtery. 1. Do I have the wrong control for the machine? Or is it kaput? 2. Photo below, if anybody can tell me if that's the same one that came with their machine. 3. If I need a new one, can you buy a new one of these simple switches for the Primeweld? I'd rather not spend $100+, which is what I'm seeing online.4. Because the TIG225x and the AHP Alphatig have the same foot pedal, I'm assuming they use the same hand amptrol, but I can't seem to find many low-cost options for that one either. Any Thoughts? Thanks!
Reply:Attachment 1706351Here's the picture
Reply:It is just a switch on and off. If its not working then it won't turn it on or off. Or maybe you do not have the controls set right on the welder.Last edited by mechanic416; 10-17-2019 at 06:36 AM.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Thanks, I'm not sure what other controls I would have to set right other than 2P. There's no foot/hand control switch like I've seen on other machines.
Reply:First anyone selling a used primeweld tig 225 is either selling the broken one that was to be returned to Primeweld under the warranty agreement or it should work. So the odds are you got a unit that someone scammed Primeweld out of, because almost all the tig 225 acdcp units are still under warranty to the original owners.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:He had a reasonable explanation for why he was selling the welder, as he was a traveling repairperson and that welder is actually quite large. He also didn't like the knobs printed out on the bottom of the dials, and I agree that this is a design flaw that makes it hard to read the machine when it is below eye level. I doubt he was ditching a failed unit, but hey, you never know. It seemed more likely to me that he grabbed the wrong switch when he was looking for all the parts. But I don't know how I would know that just by looking at the switch. I opened up the plug, and the switch goes to 1 & 2, while 7 & 3 are connected to each other. I found a video about the AHP foot pedal (which should be the same pedal as the PrimeWeld) that included a schematic of the plug suggesting the 6 & 7 are connected, so I might try connecting those two and seeing if that's the problem.Here's the link to that video for anybody who'd interested:
Reply:There are no jumpers on a trigger ( switch 1&2) only the pedal (6&7 jumper)www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Hmm...do you think there should not be a jumper between 7 & 3 in the hand switch?
Hi Entropy Dude,I could not see the picture you posted for some reason, but here is the switch that came with my Primeweld TIG 225acdcp. I have only used a pedal with my machine and have not tried the switch. Does your machine work properly with a pedal? You can also call Primeweld for help at (856) 537-4368.
MillerMatic 135Handler 210 w/ DP3035 SpoolgunLincoln AC-225Primeweld TIG225xEverlast Power Arc 200Weldcraft TIG rigSmith American Classic O/AEvolution Rage 2 SawTD Cutmaster 52Miller Thunderbolt with HF Box
Reply:Hi BorderBrewer, That looks like the same switch. Thanks for sending the photo. I'll try calling them when I have the machine set up again and can walk through the problem to see if I'm missing something. Thanks again!
Originally Posted by mechanic416
Didn't I just post how it should be wired in post #7 ??????????
Reply:Indeed, order has been restored to the universe! I got the soldering iron out,melted that jumper right off of there (so only the 1&2 were connected) and voila, the switch now works! Thanks for the help!
GMT+8, 2025-12-19 14:51 , Processed in 0.096048 second(s), 18 queries .
