Purchased Pro Pulse 300 HTP
发表于 2021-9-1 23:19:31 | 显示全部楼层 |阅读模式
Been looking for a new machine to give me some advanced pulse options and went ahead and pulled the trigger on the HTP Pro Pulse 300. This is basically a STEL Iron-Mig 303p from Italy, since I already own another STEL Tig (ESAB 281) and very happy it was an easy choice. Just showed up today, I will run it through some various processes and post back with some pics. I just bought the basic machine, I am throwing a new Tweco gun I had laying around on it and in the next few weeks get a set up for aluminum with a water cooled torch. Wired it for single phase right now, you have to put your own plug on, down the road I might see if 3 phase changes any characteristics of the welding. Fit and finish look real nice, I am impressed with the quality and user interface, took me less than a minute to figure everything out, fans are not loud at all. Couple things I noticed is the one I received does not have the door that closes over the screen, other pics I have seen have this, might be a good thing to have in my shop to keep the screen and buttons in better shape, guess time will tell, plus the gas connections are euro/non standard (I knew this and was sent the correct adaptor fitting hose). No complaints so far, I am not a fan of euro back ends on mig guns but no choice if you want this welder. The drive looks robust, dual drive with top idlers, molded plastic wire guide in back, it has a purge and inch button on the inside, to me this is a great option. Everyone at HTP was real easy to work with and truck shipping was awesome. Not much info on these machines, hopefully it lives up to my expectations. I plan on just keeping this a shop welder for now, or until the new wears off a little, I would not think of treating it like my Rebels...
ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:Bad to Da Bone ! Next on my list ! Got a few weeks to go. I don't DO cards.
Reply:You have the esab 281ac/dc? How is it? I asked esab or thermal arc 2 times at trade shows and they couldn't care less about answering or give me any information on the machine, they were to busy pushing rebels with some cable TV 4 wheel drive idiot that I didn't know til after the show and he cannot weld from what I seen on his show, or fit up tubing, guess it's to late for reviews I don't think esab sells the 281/283 anymore, and I wouldn't trust them to be a good source, maybe HTP should look at importing the Stel 281 tig or whatever cause the 221 is a little short on amps far any serious ac welding and a little to complicated
Reply:Jawslandshark, welcome to the PP300 club.
  Ive had mine for almost a year.  Kick-a#& machine!  If you don't have it already, set-up a C8-C10 gas mix for pulse/spray, and let that thing rip!Pat h, the big brother to the 221 is rumored to be available soon.  Invertig 400 AC/DC.  300A single phase, 400A 3-phase.
HTP Invertig 400HTP Invertig 221HTP ProPulse 300HTP ProPulse 200 x2HTP ProPulse 220MTSHTP Inverarc 200TLP HTP Microcut 875SC
Reply:Thanks for the info jawslandshark, I was real interested years ago ready to buy and they basically almost all but ignored me that was at a fabtech also, about 10 years before that I ran into esab at a smaller distributer trade show and they were very helpful and bent over backwards to help, guess times have changed, Oscar that's good to hear because a 220 amp machine really gets pushed hard on a lot of ac work, if they can keep the prices competitive they should do good
Reply:Got the gun on today and loaded it with some copper free ER70S-6 .035, played around with the pulse settings on c10. I have some adjustments to do on finding the sweet spot especially thinner guage, the double pulse adds a layer of complexity that I did not spend much time yet for MS, that may be an aluminum only deal since single is all I would need. I may just trial and error on some brackets I have lined up and test out the short arc with c25. I have a couple other migs to do some head to head testing and will see who has the best synergic. I am debating throwing in a roll of ER70S-2, that seems to run pulse cleaner with no spits.This is was a trial on some 10ga, single pulse just a slight roll movement. Right off the bat I noticed the program adjustments skip increments in guage thickness not in nominal thickness, there is no .250 it's .236 for say 1/4 inch for a desired amperage adjusting the IPM, then throw in the voltage trim, all of it will take some time to get used to, just a differnt way of doing things.
Reply:thanks for the proper pics, I always like to see pics of the feed rollers in a MIG welder, just gives me an idea of how much has been spent on the important bits.Looks like a topping machine
Originally Posted by shovelon
400 amps you say? 3 phase you say?
Reply:I got to mess around with the PP300 a little more today, switched from C10 to C25, wanted to test the short arc synergic. I am really impressed so far on 10 guage material (some scrap I had), by far one of the smoothest short arc synergic machines I have used for this thickness, inductance changes will soften it up really nice. Now comparing say against a Migmaster 250, it wets out just as well and about the same arc feel, the starts on the PP300 are way better. I know I am comparing apples to oranges and a MM250 is not synergic but I was just using my old Migmaster at a friends house recently and those machines kind of set the bar for thinner material short arc welding and bead appearance IMO. On to the Rebel 235, one thing I noticed right off is spatter on starts, the Rebel also did not seems to have as rapid response to CTWD, now in all fairness to the Rebel it does settle down and lay a nice weld, but by feel the PP300 just does it way nicer, I guess you get what you pay for there. I was using .035 wire in both machines but the PP did have copper free loaded, not sure that makes a differnce. Burnback setting on the PP is the best I have used so far. Ok a couple of cons so far, it would not be fair to leave that out. The Pro Pulse 300 takes a little more time to find the sweet spot with the settings, I am not thrilled with the thickness selection identification, this is where the Rebel has it beat, select common guage, tweak the volts and burn metal, the screen is easier to see also, I am nitpicking a little here, the advanced features GUI is better in the PP though. Now for the other issue that really needs a programming update, after you weld the PP keeps up the welding info for like 1 second, you barely can get your hood up to see before it switches back to standard screen and its in purple that you can't even focus, on the flip side the Rebel holds the welding amps and volts too long but you can push the button and it changes back if you don't want to wait.Now one thing that really jumped out at me is pulse on c25, really nice, liked it over c10 for the 10 guage material. The ICold for tacking, nothing better I have ever used period, perfect round tacks, no spatter and solid. I hope to take a couple quick videos of this machine in action, but that may take a bit since I am no video expert. I will get some more picture soon and also for aluminum when I get that setup figured out.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
Reply:The HTP stork flew over my house yet again!  Dropped off this baby!
That's what the lil birdie told me.  Should be interesting.  Only gripe is with the de-rating nature of it's power supply.  Would have been awesome if it would be able to do 400A on 1-Φ power. Gotta have a phase converter to get to it's peak output if all one has is 1-Φ power available.
Originally Posted by metalman21
300 amps 1-phase / 400 amps 3-phase is still a respectable amount of power. I think it beats the Lincoln Aspect 375: 375-3-phase and 250-1-phase and hopefully will cost less and be lighter.The Miller Dynasty 400 specs. state 3-400 amps 1 or 3 phase but the duty cycle is less on 1 phase. Cost of the Dynasty is considerably higher so I guess it costs more to build a machine with that much output on single phase.That HTP 400 might be the ticket for me and I'm looking forward to it. I first heard of it around last fall. Did you get any clues when it may be available?
Lil' birdie told me late Fall 2019.  We'll see.
It will be interesting to see the details. I looked on the Stel site and wondered if it will be a HTP version of this: http://www.stelgroup.it/tig-up-453h-ac-dc/?lang=en which is also shown as "Coming 2019".
Reply:I don't mig aluminum much but had some time today so I threw in a 16lb roll of .035 4043 and put in a 10ft Binzel water cooler gun. I ran some test passes on some scrap I cut up with the ironworker, 6061 and 3003 1/8. I used base program on double pulse, the 3003 was at 180 amps the 6061 at 140 amps. The system fed fine, had a couple of rats nests because I needed to adjust tensions and keep my cable straighter. I need to work on the crater fill and starts, a bit out of practice here. I am happy with the results, well for mig at least, the double pulse on the PP300 makes all the differnce, that definitely takes it a notch above the 350p and a spool gun. Still no replacement for tig welds, those I can make perfect.
Reply:Chris,nice to have some Mig aluminum capability. Sold my Esab 2200i AC/DC the other day, but working on another rig right now..In the mean time the old Thermal-arc/Lincoln 72/Tweco Eliminator pull gun will have to do. One of the best feeding setups I have used/owned..Just got done putting it together today.. I just use the little Esab for short arc, and will run the LN-25 for spray or thicker stuff.. I started  out with all the pulse units, and now I am going the other way..
I decided to make the LN just float around the shop or outside a bit, and setup the other processes on the LM-200.. I even have the LM-200-setup to run on 1/3 phase with my adapter.. (same as the 60 but 3 phase on those.) The Mill adds 5 more HP to the RPC, but never have needed it yet..Wired it to kill the Knee, and only the Spindle motor runs cluched
Last edited by Brand X; 11-19-2019 at 09:28 PM.Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:Scott, I really like all the old thermal stuff and you have a nice setup, the 2200i I always heard was a good machine just not many around. I got into the pulse with the 1/4 inch and up steel stuff I have been fabbing lately the PP300 is a good machine for that since I have a water cooled gun, I still short arc 1/8 and down, I don't do much aluminum mig just wanted to try it out. I tig almost everything aluminum, even stuff I could get away with doing mig, I get a better cleaner product. I do have a potential deal working overseas thats aluminum parts, it's a candidate for mig. We will see, this HTP still has to make its money back somehow.ESAB Rebels 215 and 235, ESAB HELIARC 281i, ESAB ET 301i, Hypertherm 85 and 45XP, Thermal Arc 185, TD 60i, HTP PRO PULSE 300
GMT+8, 2025-12-20 12:44 , Processed in 0.094628 second(s), 18 queries .
