htp 2400?
发表于 2021-9-1 23:19:31 | 显示全部楼层 |阅读模式
i am in the market for a larger welder and can get the htp 2400 for 800,  should i get it or hold out for a miller 252 or 255 or something else,  i have read htp is a good machine but not from anyone that uses them
Reply:I used one once and it is a good machine. I'd rate it power wise right in line with a Miller 252. I was going to buy one for myself but decided on a Pro Pulse 200 because of it being able to weld aluminum with out a spool gun and it has pulse programs. If I was looking for an all around steel welder 2400 would be perfect. Also HTP has excellent customer service. If that 2400 is in good shape then $800 is a deal!
GMT+8, 2025-12-20 12:46 , Processed in 0.210463 second(s), 18 queries .
