Solar 165 manual request
发表于 2021-9-1 23:19:30 | 显示全部楼层 |阅读模式
Hi everyone. I received a Solar 165 mig and am looking for the manual. Any help?
Reply:Find the 6 digit model number, look for a line of text that has the model number and machine output specs. Then go to Lincoln electric find support tab and select. parts manuals not owners manuals, owners manuals are for Lincoln products. Parts ,manuals will take you to the service navigator. you will need the model now, enter in code number box. some information should appear. make sure to scroll to bottom of the page some links are can be at the top or at the bottom. If you can't find anything send me the full name and model number by private message. I have another file I can look into. supply you email and I can send it to you. you also can send it to Lincoln from their web site and the WCTA group will get back to you.Just checked old file, will need the model number, if this is a wire feed it will start with 117-xxx. Stick welders will start with a different numbers.Last edited by ccawgc; 11-19-2019 at 12:51 AM.
GMT+8, 2025-12-19 14:54 , Processed in 0.134287 second(s), 18 queries .
