Foot Pedal for Thermal Arc TA-10/270-HE
发表于 2021-9-1 23:19:29 | 显示全部楼层 |阅读模式
I have a Thermal Arc TA-10/270-HE engine driven welder.  I am an amateur/home owner who learned to weld last year and love it.  I don't have great power options at my house, so I picked up this machine a couple months ago.  It came with a Miller S-32P suitcase so I can stick and mig weld right now.   Engine runs well and so far welds pretty good.  The front panel has a switch for tig lift start, so I picked up a CK tig torch to do some tig welding.  It's a two-piece torch with manual gas valve.  I didn't really pay attention when I got the machine, but noticed yesterday it has a 14-pin connector.  Based on the panel, it appears it could remotely control the amps with a pedal. Does anyone have experience using a pedal with this or similar machine?  Curious what make/model pedal would work.ThanksNick
Reply: I don't anything about that machine but check with the people at https://www.ssccontrols.com/Last edited by metalman21; 11-24-2019 at 09:45 AM.Ernie F.
Reply:I used to have one.   I believe all the TA stuff was miller compatible.    Plus you have 3 phase power generator at 460vac with that machine.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Generally a 1k pot on the Millers, and 5k in the Thermal-arcs ft control.. Never really made a difference in the digital inverters I have used.. Might be with the analog machine?I would probably just stick with 5k pot ft control on that one. Although if you had a 14 pin Miller pedal, I would give it a go..Esab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
Reply:SSC can supply a foot pedal just give them a call.
Reply:Thanks guys.  I went to the site and it looks like the C81-1425 has the 14-pin connector that matches mine.  I'm going to call to confirm.https://www.ssccontrols.com/tig-cross-reference-guide/
GMT+8, 2025-12-19 14:55 , Processed in 0.095464 second(s), 18 queries .
