45xp p/n for plasma table?
发表于 2021-9-1 23:19:24 | 显示全部楼层 |阅读模式
Looking to get a 45xp to put on a Bulltear table with candcnc controls to replace older hypertherm unit.  Candcnc indicate I should ensure plasma unit has rs485.    It appears the hypertherm pn 088119 is the right one, if I'm reading the chart correctly it's 220v, 25' machine torch, cpc port plus "serial" which I assume is rs485.   088116 has same description but no mention of serial.  Has anyone bought the 008119 and confirm this?   I'll also have to purchase the candcnc advanced connection kit.  Thanks!
Reply:Well the LWS says the 119 has the rs485 serial but its $350cdn more than the 116. Doesn't make sense as the field add on serial is what, $170usd Ian?  230cdn or so.  Do I get something else with the 119 or ?
Reply:The 119 is more expensive because it includes interconnecting cables.......you should get those from CandCNC.com   as the Hypertherm cables will not have the right connectors for the CandCNC ends.I am on the road all week, so it is difficult for me to look up all combinations of part numbers .....you can always call Hypertherm customer service and they can help you choose the right system for your needs.  Looking quickly on the web page...it does not look like there is a single part number that will get what you want...so I would suggest ordering A La Carte:Power supply, 45 XP CSA with CPC, Serial Port     088105Starter consumable kit  machine cutting    42856025' machine torch        088167work cable          223595If you order like this you also need to specify an operators manual.     Best regards, Jim Colt    Hypertherm
Reply:thanks Jim. On your advice I spoke to customer support and will be ordering the following (in case this helps anyone else).  A bit easier to keep straight than a la carte.  HYP 088116  (45xp w/25' machine torch) HYP 428654 45xp serial upgrade kitHYP 088165   (50' hand torch) HYP 223596  (50' work cable with clamp)
GMT+8, 2025-12-20 12:21 , Processed in 0.094836 second(s), 18 queries .
