Thoughts on the HF stand up Drill Press's?
发表于 2021-9-1 23:19:18 | 显示全部楼层 |阅读模式
I am in the market for a home use stand up drill press. I work with mild steel and basically 3/8" is the thickest material I work with and that's only on a special occasion. About 90 percent with be 1/4 and 3/16" thick. I have a friend that works there so I can get employee discount. Will these work for what I want or is there a better option? I want to stay under 600.00
GMT+8, 2025-12-20 12:45 , Processed in 0.089608 second(s), 18 queries .
