HF170 converted to gas: issues
发表于 2021-9-1 23:19:16 | 显示全部楼层 |阅读模式
Good evening all,I took the steps to convert my HF170, which was previously used many times with flux core, over to gas shielded.  New bottle (AC25), new regulator/flow meter, all connected.  Pulled old empty FC spool, ran a new solid wire 0.030 spool.  Swapped polarity to electrode positive.  Set wire tension to bend against a wood block at 2-3 inches per the manual.Went to lay a few beads to test it out.  First bead was on Max/1 with the wire speed maxed out (mistake. I didn't reset after running the new wire through the sheath.)  Welded fine, albeit a bit hot because of the wire speed.  Realizing my mistake I made some adjustments, down to Min/2 wire speed about 5 and tried again.  Now i can't get it to hold an arc.  I get a pop upon first connection, goes out, wire appears to struggle(?) then another pop, repeat, repeat.  I'm also getting a fairly large glowing red/white ball on the end of the wire.  If I crank the speed back up to 10 on the min settings, I can hold an arc, but it sounds like a string of fire crackers going off rather than a nice hiss.I'm sure i flubbed something up in the swap, but i'm new to this so i'm not sure what.  Thoughts?
Reply:Thanks for the input!  For my own sanity i'm going to remove everything and run it again just to be sure, bu thats really good to know.  So basically I should forget all my "common" settings from using flux core (i used to use this range regularly) and start from scratch?
GMT+8, 2025-12-19 16:20 , Processed in 0.092006 second(s), 18 queries .
