查看: 13|回复: 0
OLD Lincoln weldanpower 225 thd wisconsin
发表于 2021-9-1 23:19:13 | 显示全部楼层 |阅读模式
First post so bare with me ...i'm an old diesel tech and generator repair man semi retired but can't find the needed ohm specs for the rotor, exciter coil and stator...here is my unit:Weldanpower 225 AC-225/5-AS ....Wisconsin thd 2 clydcode 5229 rotor # WP256-6....field exciter coil FBS5-Z....power stator WP256-10...internal stator diagram M10066exciter armature M4425-3/24.70A.......Lincoln says all the old timers like me have retired or died and i still like to work on old junk but i do need some HELP specs on this old girl....rats got the wiring....this is a great forum for working folks keep up the great work...thanks,joe
Reply:Wasillashack  Did you get any further with your 225 Ranger? I am working on one for a welder friend, and I downloaded a service manual from an online site. I can send you a link for it if needed (and it's not against the rules here.Thanks
Reply:just send it to him by Private message.
Reply:Geronimojoe, I sold all my Weldanpowers (2) and Lincwelders(2)plus many parts in preparation for a move to Texas. As luck would have it I found  a Weldanpower with CC/CV for $100 so I bit the bullet and bought it, it needs a little work, but for the price I couldn't pass it up. Back surgery last rear and two knee replacements this year will limit progress, I really appreciate all the help I have gotten from the WW site. Thanks to all. I got sidetracked a little with the purchase of a Link Arc welder (now Premier) I will be installing on my flat bed dump truck, couldn't pass it up for $25, it needed a volt gauge, $5 from ebay for an exact duplicate. If you don't mind, I always welcome information on my welders, PM it please, and thank you.
Reply:n2diesel.I believe I have a factory manual for Wisconsin THD/TFD's if you need any info about the engine. It is a hard copy so I would need to get it converted to an electronic format to send to you, HTH, Good luck!
GMT+8, 2025-12-20 12:21 , Processed in 0.088098 second(s), 18 queries .
