Ranger GXT age.... help please
发表于 2021-9-1 23:19:12 | 显示全部楼层 |阅读模式
Can someone help me with the year of this Ranger??? Thanks,Tom
Reply:I'm not a Lincoln expert, but I'm pretty sure it's 2007.  The serial number is where you'll find it.  The U1 means it was made in the U.S.  Newer machines will have M for Mexico.  The third and fourth digit are the year...07, so 2007.Check out my bench vise website:  http://mivise.comMiller Syncrowave 250DXMillermatic 350P with XR AlumaProMiller Regency 200 with 22A feeder and Spoolmatic 3Hobart Champion EliteEverlast PowerTig 210EXT
Reply:august 2007
Reply:Guys,Thanks you both. This machine is a back burner project. I'm just seeing this thread.I'm finding that the engine runs fine in low idle and full throttle but I am getting only 33ish volt AC and no 240 volts. When trying to strike an arc I get only a spark at best. This is on both AC and DC.Thanks,Tom
Reply:I'm over on the other side of Pinnacle from you at the corner of Old Mill and Tillotson Rds.  I should have a GTX 225 service manual in a pdf.  Let me get a look at it later this evening and maybe I can figure out the most likely cause(s) and get back to you.Off the top of my head though, I'd be looking at the slip rings and whether they need cleaning and that the brushes are in good shape and making good contact followed by a check of the flashing voltage (2.5 VDC) at the brushes and 12VDC at the circuit board. And given the condition of the face plate and case I'd advise a good general cleaning and inspection of the interior of the welder to be sure there's no major corrosion or vermin damage before running it again.I make no claim to being an expert but I have refurbished a number of these over the years (maybe 12-14?) and I'd be glad to stop by the next time I'm at the gas station or post office in the thriving metropolis of Pinnacle.Best regards,LanceLanceMultimatic 255 w/MDX-250 EZ-Select gunHypertherm Powermax45 XPHeck Bevel Mill 4000Miller/Smith heavy duty torch set9" Evolution circular saw
Reply:Lance,I'm going to open it up and take a look the engine wise I have it back to life. Engine drive machines are foreign to me. I'm sending you a PM.Thanks,Tom
GMT+8, 2025-12-20 12:20 , Processed in 0.090931 second(s), 18 queries .
